Running wires inside bars. I'm confused
Old 02-05-2009, 07:37 PM
Trash Rat's Avatar
Trash Rat
Trash Rat is offline
Default Running wires inside bars. I'm confused
Ok, once again I'm confused. I finally got everything I need to finish installing my 12.5" apes on my 99 Fatboy. I ran my left side wires, (switch & turn signal), & they went though the bar relatively easy. I thought "piece of cake". I started mounting my controls, only to find out that the turn signal wires,(I'm mounting the signals in the stock location under the clutch lever mount), are preventing the switch mount from fitting up against the clutch lever mount. Am I going to have to run the signal wires on the outside of the bars? I thought about moving them, but I have a quick disconnect windshield, & auxillary lights & really don't see how or where I could move them to. Any help here would be appreciated as I'm really tired of my bike being torn apart. The weather here says I have plenty of time to finish this, but my lack of patients says it's time to get it done, & see how purty it's gonna be. Thanks.
Frank
Old 02-05-2009, 07:45 PM
crazybastid83's Avatar
crazybastid83
crazybastid83 is offline
You can run all the wires inside the bar, not a problem at all. Did you drill out a hole in the switch housing for the turn signal wires to exit, to mount them on the bar?
If you look at a new fatboy it is all internally wired. It has a hole with a grommet where the turn signal wire exits. You do no have a large enough hole in the bottom of the switch housing. It needs to be drilled out.
Old 02-05-2009, 08:00 PM
57RebelRocker's Avatar
57RebelRocker
57RebelRocker is offline
sounds like your question has been answered...good luck
Old 02-05-2009, 08:56 PM
RockyTopRider's Avatar
RockyTopRider
RockyTopRider is offline
no help on the wires. tomhummer that is the worlds best avitar!!
Old 02-05-2009, 09:51 PM
Trash Rat's Avatar
Trash Rat
Thanks crazybastid83. I found the hole on the left side & got it drilled out. Worked perfect. There's no hole on the right side, but it looks like there's room to drill one. It'll be close to a small metal bracket on the inside of the housing, but I think I can make it work. Thanks again.
Frank
Old 02-05-2009, 09:56 PM
Mordrapheus's Avatar
Mordrapheus
Mordrapheus is offline
there you go, now you just have to show us some pics
Old 02-06-2009, 04:38 AM
Blk and Chrome's Avatar
Blk and Chrome
Blk and Chrome is offline
Tom glad to see she finally shed the panties, very nice,
Old 02-06-2009, 08:18 AM
keno's Avatar
keno
keno is offline
Yep I could sit here looking at, er reading tomhummers 'answer" all day .. LOL
Old 02-06-2009, 09:57 AM
Alain's Avatar
Alain
Alain is offline
it sure is
Old 02-06-2009, 10:23 AM
bcox's Avatar
bcox
bcox is offline
Don't forget the pics......I'm thinking about 12.5's too and curious how they look.
Quick Reply: Running wires inside bars. I'm confused
