Question about cutting baffles in half?
Drill press is the answer
If you pulled the baffles completely out, you probably don't have enough back pressure to make it run properly.
I pulled the baffles out of Screamin Eagle pipes, threw away the fiberglass and screen wire, and then doubled the amout of holes in the baffles. I did not touch the center deflector in the baffle--it is still just like factory.
All this work allowed the 96B motor to breather better. The bike actually runs better now and has less vibration. It has a nice sound also.
not sure about cutting them in half. have you checked out the thunder monsters by big city thunder. i think they are 50 bucks and they deliver an awesome sound
Modified baffle
As long as you cut the baffle after the deflector, it should have some back pressure and should run okay. If you cut it in front of the deflector and try to bend some piece of metal into the exhaust flow to create backpressure, who knows what you will get.
Trouble with cutting it is--once its cut its too late to back out unless you have a welder.
Good luck, hope it works for you.
