efi internal question
Old Mar 19, 2009 | 12:51 PM
hogdiver96's Avatar
hogdiver96
Default efi internal question
Ok i hope some-one can help me here !
About 6 months ago somebody was kind enough to post a link to a video explaining how to get the guts out off an efi tank without breaking it THANK-YOU
But now new question...i am putting back together again and i can get the guts back in but the plate it is bolted to does not sit well and straight on the tank...if you look in the tank on the left hand side there is a vertical bar welded in the tank...does the springy arm thing with the fuel filter on the end go the far side off it to the left off the tank or does it sit jammed up againts it..sorry cant explain any clearer than that (07fxstc)
Old Mar 19, 2009 | 01:37 PM
Mordrapheus's Avatar
Mordrapheus
personally I can't answer that, but I would suggest popping down to your dealer, or going online and buying the service manual, that would show you where and how to place it.
good luck
Old Mar 20, 2009 | 07:24 AM
tk353's Avatar
tk353
wow i just bought a used manual for 07 softail on the is forum for $20. I will look it up for you. it only says to install untill rubber gasket meets tank. the removal shows starting by moving forward and up.
skipper469
Aug 16, 2015 07:28 PM
Dutch101st
Feb 28, 2015 05:50 AM
jarheadsgt
Feb 12, 2013 01:56 PM
greg3131
Exhaust System Topics
Aug 12, 2012 03:21 PM
Curious.Yogurt
Jun 30, 2009 04:06 PM
