Springer Families - Unlock The Mystery.
Any 21 inch wheel will work as long as it is fitted with bearings that will accept the correct diameter axle. After that, spacers may have to be fabricated to center the wheel. And of course the hub will need provisions to mount the brake rotor.
As far as I know, the forks are interchangeable between FX and FL "Springer" models. As previously noted, apparent rake differences are probably optical illusion due to different tire. You can probably use raked cups with your bike to stick the fork out. As far a a different wheel, probably the cheapest and easiest (besides being old school) is to lace up an 18" or 21" to your existing hub. If you buy a new wheel, it should just be a matter of getting the spacers right.
Good luck , anxious to see the results.
I'm thinking the FL Springer is just the FX Springer put on a different frame. The FX was the original modern Springer, IIRC introduced on the Springer Softail around 1988. The Heritage Springer used the same springer IIRC.
The FX frames are enough different that they don't adapt readily to footboards. That's all the further my research went.
The Springer is a great riding bike, I can tell you that.
Thanks for the responce.
Thanks thats some good information, I'll add it to my original post. I wonder why the HD Parts appears to omit 08 and later Springer Models from all there wheel fitment descriptions?
I am begining to beleive that the fork assembly is the same and perhaps just the rockers are different...?
I'm not looking for extreme rake, I was looking at an older FX the other day and really liked the fork angle so harley FX stock I think would be fine, just trying to figure out how to get their from here. As for the wheel, I never thought of that. I'm sure that would help me garauntee fitment. Ever laced a wheel yourself? I think I saw the proceedure in my manual. I'll check it out thanks.
The lacing is not the hard part. Check the angle of the existing spokes so you'll know the inner from the outer ones. It really will only go together one way, although on occasion I've seen them off by a hole and guys trying to figure out why the last few spokes just won;t fit.
The harder part is truing the wheel. There are truing stands available, but we used to do it with a crude stand made from a couple of pieces of 2" x 4" and the axle. If you get it close, there is probably a shop that specializes in dirt bikes near you that can finish it off for not much $.
Frames are all the same.....
Rake is in the trees, or in the rockers.
The springer front end is also the same.
As said before
FL= 16" front wheel.
FX= 18 or 21" wheel.
Getting a wheel to fit is all about using the proper spacing..
As said before
The FX Springer I had (2000) had quite a bit more rake than a newer springer like a Rocker or a Heritage. What was different is a mystery to me but the boards were not available to fit the FX frame. I checked.
