I was wondering I am going to put drag bars on my deuce and I was going to put a 6 inch rise drag bar on but someone told me that you have to put a minimum of a 7 inch rise because a 6 inch will interfear with the speedometer or something. Does anyone know anything about this?
thanks. ya demon cycles has a handlebar kit so I wanted to buy it but i wanted to make sure that the rise was ok. Do you have any other photos of the bike? also did you have to get different size cables?
cobra
I put mine straight on,there is an adapter you can purchase but you don't need it. Have you decided on a set with built in risers. I rode with the Deuce risers and flat drag bars for a time then was given the set I am using now. Not alot of difference between the two set ups.
ya I bought a set from demons cycle in florida. they are the one p[iece bar with the built in riser. but someone I know put carlini drags on his bike and he said he needed some adapter that I wasnt sure about. so I was wondering if I should order the adapters to be safe.
i have a set of low profile drags on my deuce from wild 1. go to wild 1 .com and check them out. they look fantastic. they only have a 4 inch rise and i did not have to relocate my turn signals but i did anyways.
The Deuce bars are not bush mounted so the risers tighten down on the tripple tree,this is where the adapter is required if the risers are not thick enough as in diameter. Mine were OK and I've seen many fitted without requiring the adapter. Get the bars and then decide if you need it.
ORIGINAL: cobra9498
