Bleeding the front brake
Along with kits proposed here there are reverse bleeder kits that push fluid up through the bleeder valve toward the master cylinder. Going that way you push the air up where it naturally wants to go.
I made my own from a piece of flex tubing and a pump oil can. I think it cost $5 total. Only took 10-15 minutes tops.
Whatever method you use, if you spend more than 5-10 minutes without a change in lever pressure you have a problem and need to reassess.
Easy way for me would be to open the bleeder and don't do anything wait for gravity to do its job once I see brake fluid dribbling out I tighten and then do the pump hold bleed works every time. keeps the air from forming bubbles.......anyway????????? guess there is more than one way to skin a cat. oops hope no one here is with aspca
I have tried many different methods, gravity bleed is the best way to go unless you have a speed bleeder, many auto parts stores sell one way check valve bleeder that works very well. I have a fluid vac at work, bleeding is a piece of cake.
Try this is you don't have anything.
1. Top up the fluid
2. Crack the bleeder screw open
3. Hold the brake lever slowly
4. Close the bleeder screw
5. Let the brake lever return
6. Back to step 2 and repeat until you get a firm grip.
Good luck!
1. Top up the fluid
Good luck!
or a sqeezable ketchup bottle with spout and flex tubing, blow brake fluid back through and out the master cylinder ...been doing it for years and it never fails...ever
- Put teflon tape on bleeder screw threads
- Install bleeder screw and leave open 1/4 turn
- Take oil can and pump brake fluid thru bleeder screw
- Close bleeder screw
- Drink beer...your done
GibsonSG05
06-13-2021 02:14 PM
