help carlini bars Rocker c
Old Oct 28, 2009 | 12:10 PM
skipdogg01's Avatar
skipdogg01
Question help carlini bars Rocker c
Hi all i am trying ti install my new Carlini bars on my Rocker c does anyone know how to get the wires lose from the connectors so i can run them through the bars.
Thanks Skippy
Old Oct 28, 2009 | 01:32 PM
Rocker_C's Avatar
Rocker_C
Most likely you will need a pin extractor for the connectors. You can get one at Radio Shack. It slides into the hole in the connector and closes the catch on the pins so you can pull them out and reuse them. Make sure you write down witch wire came out of each hole. Most connectors are numbered. Also there are different size pin extractors.
Old Oct 28, 2009 | 01:35 PM
jed1069's Avatar
jed1069
Shove a paperclip into the little hole. You will feel a little release then gently pull on the wire. I made a wire diagram and also snapped a digital picture for back up before I took them out. If you have a manual there is a section in the appendix that describes how to dissasemble each connector on your bike.
Old Oct 28, 2009 | 01:58 PM
Hockey Stick's Avatar
Hockey Stick
This site may help
http://www.wild1inc.com/techtipswiring.html
Old Oct 28, 2009 | 03:30 PM
rayrayray's Avatar
rayrayray
show some pics when you get them on
Old Oct 29, 2009 | 08:33 AM
skipdogg01's Avatar
skipdogg01
Default Thanks
Thanks guys for all your help this is a pain in the butt, for some reason its taking a lot of time to get the wires out of the connector its a hit or miss but i will get it, all your advice was very helpful and i thank all of you.
Skippy
BLK08ROCKERC
Mar 21, 2010 07:52 AM
entourage
Oct 25, 2009 10:22 PM
masar
Aug 27, 2009 10:47 PM
tripwire759
Jul 16, 2009 11:44 AM
57RebelRocker
Electrical/Lighting/Alarm
Jan 13, 2009 10:01 AM
