RockerC- Tank Lift & Rocker Box Bolt Covers
Quick Question.
After installing the Tank Lift how many Rocker Box Bolt Covers will I need to cover the visible hardware? Eight are Visible without the lift, will application of the lift make the other 4 Visible??
Haven't installed the tank lift yet as I am still trying to decide on what to replace my signal lights with or to move them etc... any thoughts on this as well?
Thanks
NewfieRcker
Thanks
NewfieRcker
Quick Question.
Thanks
NewfieRcker
Thanks
NewfieRcker
Newfie, all 12 rocker box bolts will be visible with the tank lift
I have been working with Jeri of Jeri's Springer and it should be sometime towards the end of March. Already have the front fender chopped, working on the rear fender this month, getting them painted once the springer is on, and should have my custom made BR bars soon. Decided to go with an internal throttle to cut down on external cables.
I borrowed a picture HiSpeed took of his fender and designed a cut in Photoshop. Want to put a Spine down through the tail so it looks like a Dragon's Tail. Also redesigned the front fender and had it chopped (below).
