Cam suggestions!!
Old Nov 30, 2010 | 08:06 PM
xxxflhrci's Avatar
xxxflhrci
Originally Posted by Reino_79
While were on cams I have a dumb question. A friend is getting ready to do cams on his 05 (I think) Dyna. Hes not sure what cams are in the bike as hes the 3rd owner but the previous owner told him he thought they were stock. Is there anyway to look at the cams when he takes them out to see exactly what was in there?
Yes, the end of the cam should have a number on them. Stock carb Twin Cam cams have a "A" on them. FI will have a "B".
Old Nov 30, 2010 | 08:35 PM
klf33's Avatar
klf33
Bump for an answer to my dumb question?
that is actually a tough one to answer for me.. I would be enlightened with an answer I am sure .
Old Nov 30, 2010 | 11:54 PM
oct1949's Avatar
oct1949
Originally Posted by Charlie Harlie
Lads, Looking for some cam suggestions. I have 2002 fatboy which i will be replacing cam tensioner pads soon and fitting EZ rods or similar, new roller bearings. Any ways its stage 1 SE pipes, MIK42 carb. Since i will have it open any suggestions what carb to fit, probably mid range up !!!
Any ideas would be great.
just a question??????????
Do U really run U motor from 3,500 to 6,000 rpms most of the time... thats the range for Mid up cams...Like the 37s
So no putting around or two up riding??
Old Dec 1, 2010 | 07:39 AM
06 flstfise's Avatar
06 flstfise
I am running the andrews 37n in my 06 fatboy with a 95 inch kit stock heads. It is great for one up riding and ok for two up. I am thinking about getting the heads done to get the compression right and see if it will help on the two up riding. It is better than the stock cam for two up though, just need to keep the RPM up a little. At 2700 I am hitting 90 lbs of torque and it climbs from there. Also I would look into the cam conversion kit from anyone of the numerous vendors. I did the conversion on mine for piece of mind and did not want to have to worry about run out for the gears.
Old Dec 1, 2010 | 09:10 AM
OldBoldPilot's Avatar
OldBoldPilot
Originally Posted by Wild Grover
Ran a HQ034 in before turning it in a full 95 kit. Very good all around cam.
That's what I'm running right now. Serious kick-in-the-butt boost. Extremely satisfied, to the point where I decided to forgo any head work.
Old Dec 1, 2010 | 09:37 AM
klf33's Avatar
klf33
+1 on the that change, take a look at the thread I started here on the disaster that was about to happen to my stocker cam bearings around 36K
I did go with the 37's as the juggs will go next year (budget budget), I started with the cam since I was changing the tensioners. and we will see now that I am married how much 2-up I will do.
Old Dec 1, 2010 | 10:44 AM
Weevil's Avatar
Weevil
Do a little research.
http://www.mikuni.com/fs-performance_guide.html
http://www.nightrider.com/biketech/h...m_bydur_ql.htm
http://www.*****************/forums/tw...bers-mean.html
MPH/RPM's in 5th Gear (3:15 gearing in your '02)
MPH RPM's
45.....1907
50.....2119
55.....2331
60.....2543
65.....2755
70.....2966
75.....3178
80.....3390
85.....3602
90.....3814
95.....4026
100...4238
Old Dec 1, 2010 | 01:16 PM
djl's Avatar
djl
Andrews TW26 is probably the best cam for a "cam only" upgrade. Once you start to go bigger, you really need some headwork to support the larger cams. The 26 will start to fade about 4000 and be all in about 4500 so not much help midrange up. If you really need midrange up, you should consider increasing displacement to 98" and head work.
The Mik42 is enough carb but a tunable ignition will help get the most from a tune. You didn't mention exhaust; very important component, particulalry for a cam only upgtade.
Old Dec 3, 2010 | 02:15 AM
Charlie Harlie's Avatar
Charlie Harlie
oct1949
Thats the sort of range i am looking at!!!!
Same as a few guys here. I want to put best cams in just now, as 95 heads going on next year.
Running screaming eagle pipes.
Thanks for all the input lads!!!
Old Dec 3, 2010 | 08:09 AM
klf33's Avatar
klf33
oct1949
While I ride in the city a lot, I realized that I am actually never under 2800, (that is if you want to stay alive ), so I must say that the 37 looked like a better 'get out of trouble' option for me, and also, a step for further work down the road as others stated (bigger jugs on year later, head work / valve springs the year after) etc.
The difference in power/torque in the 2000/2500 rpm range between the 21-26 and the 37 is only felt in lazy shifting cruising on the free ways, which is really fun but not where I am at most of the time .
The downside for me is this stupid Elbow pain I get now from the clutch pull, easy pull is not helping and it seems I will join a line up of tank shifters soon either way .
