Can I use a female shifter peg on my Deluxe?
I bought grips and would like the matching toe peg below. But all the shifter pegs I see on Harley's website are all male, and this one is female.
Will I still be able to use it? I would think all I would need to do is find the right size threader?
(cut me some slack, I'm a chick and still learning about mods)
Thanks!
http://www.smtmachining.com/products.asp?PRODUCT_ID=148
Thanks!
I don't see why you couldn't. Take the stock shifter peg off and go to a Ace Hardware. They have displays with different size bolts and nuts to make sure of the sizing and thread.
They have hardened bolts that you could cut the head off and use red loctite to attach to the female peg and then mount it as a normal peg.
I had someone on the Forum make me a pair of matching shifter pegs. They look awesome. You will be surprised the difference something like that makes. He matched my Leroy Thompson grips to the tee.
Since 5/16 x 24 (24 threads per inch)is oem standard threads on the Harley shifter pegs...What i would do is go to your local Ace Hardware and buy a 1 1/2" 5/16 X 24 (Or longer if they have it) chrome buttonhead bolt and thread it into your shifter until it stops, then put some threadlocker on the exposed threads and thread your female shifter on. No problemo.
What Jimmy said ....
