Softbrake Installation Question
I'm going to order the Tombstone light housing and plate relocator, but after reading threads on what a PITA it is to install them, I'm re-thinking it.
My bike has stock suspension and I don't have a jack....is it gonna be impossible to do? I was also thinking about getting a set of thumb drives to make it easier.
To me, it looks like 3 screws to remove the lens, then there is a cover on the inside of the fender (how is attached to the inside of the fender), you remove this plastic cover and you have to remove 3 nuts.....then put the Softbrake kit on and re-install. How off am I?
Bro if you have even the slightest mechanical know how you can do it. It only takes like 10 mins to install i did mine with out a jack just had the air ride at stock height. I used a universal deep socket and an extension easy as that. I never really understood what people say is so hard about this mod. Or how they let it kick their butts
There is one screw holding on a plastic plate that covers the wiring from water and debris, and three holding on the plate light housing
It's not hard. I didn't use a jack and was able to get my hand and arm in between the tire and fender to reach the bolts. Just make sure you have a long 7/16th wrench (a ratchet action if you have one)
If your really, really not sure just get a side mounted plate and the Tombstone
But I did it and I'm like a 3 out of 10 on mechanical skills
