Samson True Duals s2-439 on 09 Deluxe Install Help
I wish I could figure out how to put a picture up so you could see where I'm at.
OK more pics for you brotha.I had a hard time with the rear nut on the last jug as well.My reason being I run the harley chrome inner primary cover.I had to position the rear head pipe upwards a little to clear the added height from the primary cover.Also had to trim the primary cover because the new shift linkage was binding on it. But thats for a different thread.I bought a cheap 1/2" open/box end wrench.I bent it it my vice at about a 90* angle.I put a 1/4 socket ext into the box end to tighten as pictured.I was only able to get like a 1/8 of a turn on the nut before re adjusting the wrench. Just took a little longer to tighten.But it worked like a charm and was the only thing that worked for me.Due to my circumstances(didn't want to loose my inner primary cover).Hopefully in the one pic you can see how I have the crossover clamp situated.Also I am not sure what you mean by the seam.The cross over pipe slides over the head pipe.So that clamp should be situated totally on the cross over pipe then tightened.Not trying to split the difference.1/2 the clamp surface on the head pipe and 1/2 the clamp surface on the cross over pipe.If I am understanding you correctly. Hope this makes sense.
Any time man .Any more question just ask.There are so many knowledgable people on this forum its crazy.I am like at the bottom of the food chain.The duals require a little more work and fine tuning but they are worth it in the end.Just don't get discouraged and lose faith.You'll get it done.
This just goes to show you that even a friggin IT guy can have issues. I setup an account last night on ImageShack so I could post some pictures up for you guys and I'll be danged if I can't figure out how in the world to post 'em. Any suggestions?
