Cleaning solid wheels
Old Jul 13, 2011 | 01:03 PM
martinspencer's Avatar
martinspencer
Default Cleaning solid wheels
Amigos,
i have an '03 Fatboy. The solid wheels have a very deep set, mottled, staining which is much more noticeable on the side of the brake discs. I have tried to remove the "staining" with steel wool pads, Dremel metal polish wheel, rubbing compound, Nev'r Dull . . . all to no effect.
Does anyone know how make the wheels **** and span again?
Thanks!
Old Jul 13, 2011 | 01:08 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Sand with multiple fine grade sand paper and polish. Mine were rather pitted when I got them and I used s100 polishing soap on them for the pitting. It worked well but it sounds like yours are much worse.
Drew
Old Jul 13, 2011 | 01:29 PM
AjAnd3rson's Avatar
AjAnd3rson
I love how you were censored on $pic....
It's a product not a derogatory term...
Old Jul 13, 2011 | 01:32 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
That is funny.
Drew
Old Jul 13, 2011 | 02:55 PM
Hot Rod King's Avatar
Hot Rod King
sounds like its time to buy a new wheel ... haha. I totally understand, having the same problem. Im ordering a new chrome wheel soon
Old Jul 13, 2011 | 04:14 PM
SurfGuitar141's Avatar
SurfGuitar141
I'm in the same boat with an '03 Fat Boy, brake dust has etched it's way into the aluminum, other sides of the wheels cleaned up nice, but the brake sides are ugly. Tried everything mixed with a lot of elbow grease, and nothing seems to clean them up. Gotta try the S100 polishing soap next, after that it's wet sanding.....
Old Jul 14, 2011 | 01:22 PM
martinspencer
Thanks, guys. I did some searching through old posts and saw that wet sanding using progressively finer papers should obtain the best results.
Old Aug 4, 2011 | 05:32 PM
mike06train's Avatar
mike06train
Did you try this yet? How did it work out?
Old Aug 4, 2011 | 08:34 PM
cmosentine's Avatar
cmosentine
Mine were in terrible shape. The previous owner must have never cleaned the wheels. I used synthetic steel wool (scotchbrite). Started wet sanding with the red pad until I could not really feel the pits. Then went to the gray pad for the final sanding, followed by Mothers polish on a power ball. Wheels look as good as new.
Old Aug 4, 2011 | 08:41 PM
oct1949's Avatar
oct1949
There's several auto tire and rims shops around here that will polish older wheels back to new looking.
Might try to see If they'll do a bike rim... thinking it'd be a lot less greenbacks $$$$ than a new set of wheels
