Shotgun-Fatboy Lo-Transmission drain
For a 2010 Fatboy Lo it's not as simple as just removing the two bolts. For those who have not done it you lift the bike so the rear tire is off the ground, in my case I used a Sears yellow jack. You unscrew the two 3/4" bolts, I used a socket. Place a floor or scissor jack under the rear tire and lift the tire which pulls the shock back so it clears the support bracket on the frame. The shock will swing downward 90 degrees so you can get to the drain plug. After you drain the fluid and replace the drain bolt you lower the tire as you hold the shock up in place and start the screws by hand. I then lower the tire all the way and snugged up the two shock bolts.
Drew
tranny plug
the suction process seems like a good way to do this, you can pick up a decent one for about 20 to 25 dollars .there are some good marine ones around harbor fright has them. some riders with out a shot gun use this system they are afraid of stripping the plug or cross threading it. If i were running a shotgun i would use the suction process
Really, it is two bolts. I have been draining my transmission through the transmission drain plug hole for 6 years without issue. You would really have to mess up the threads to strip the aluminum. When the stock shocks are on it is a little more difficult to get the plug back in as the shocks are kind of in the way, but with the Shotgun Shock dropped out of the way you ave full access to the plug with no obstructions at all.
Drew
Drew
