Deuce tank gutting
Old Nov 2, 2011 | 09:32 AM
brihvac's Avatar
brihvac
Default Deuce tank gutting
I have a custom paint set that I want install. How hard is it to take everything in the tank out and transfer it to the new one? I have a manual and it looks like its gonna be a pain. Anyone done this that has some advice? I have had the tank off many times but I have never gutted one.
Old Nov 2, 2011 | 10:19 AM
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
not hard, make sure you use a new gasket for the top, and I would get new plastic lines as well. its a little tricky getting the sending unit in place so be patient, just got to find the right twist
Old Nov 2, 2011 | 04:00 PM
brihvac's Avatar
brihvac
New gaskets, clamps, and plastic lines, ok. Should I get a new check valve for the new tank and just leave the other screwed into the old tank?
Old Nov 2, 2011 | 07:45 PM
harleycharlie1992
that will come out with the lines, you can use it over
Old Nov 2, 2011 | 08:38 PM
Rakthi's Avatar
Rakthi
You will also need new screws when you re-install the top plate. The screws have a teflon collar at the top that can only be compressed once.
Be sure to do the job in a well ventilated area.
Old Nov 2, 2011 | 08:48 PM
2black1s's Avatar
2black1s
I had to replace the tank on my Duece several years ago.
What I vaguely remember is what a bitch it was to figure out the hinging and twisting necessary to get the fuel pump/filter/sending unit assembly out of the tank.
Once you get it out and can see how it all works it's really pretty simple - but the first time it's gonna be a bitch unless you get really lucky. It's been so long since I did mine that if I had to do it again today I'd probably struggle a bit.
Patience is mandatory!
gduncan
Apr 21, 2018 04:37 AM
Juiced_deuce
Jan 1, 2014 10:48 PM
coo1breeze
Carburetor Related
Oct 12, 2013 08:38 PM
freekdawg1200
Aug 25, 2008 05:11 PM
GothMetalGuitarist
Feb 1, 2008 01:07 PM
