Gas Tank Removal/Install
When I reinstall, I will likely use some lubricant on the rubber gasket. I've heard of a diluted soap solution, maybe isopropyl alcohol, maybe just water...
I did this too when removing the tank. I was surprised afterwards at how long it took to drain the gas, one side at a time.
Then with the vise grips still attached I put the tank over the gas can, removed one and drained that side, then the next side.
Most of that went in the gas can, not all, but it was a lot neater then I imagined it being.
I bought a cheap siphon from home depot and got most of the gas out first.
I drained one side at a time as well. Most of the gas ended up in a can, and I think now, into my snowblower!
I only had a little bit spill, but it was better than it spilling all over the bike...
I thought it would never end LOL.
Not a drop on the bike which was good.
Now if I didn't lift the back too high and scratch the rocker it would have been a 100% successful job. I did forget to remove one wire while lifting but that was easily resolved.
Oh well, I'm in no hurry. It's cold, windy, rainy nasty weather in Maryland so I have time...
This forum proves its worth for this noob everyday! Another great tip learned, thanks blksoftail!
The kind that uses the big rubber gaskets and a rope.
I'll have to find some. Great tip, thanks!
One invaluable tool is the long bar that a razor blade attaches to the end.
That is what I used to cut the rubber hose.
My normal utility knife couldn't get in there very well.
skullcrusher
03-05-2009 07:30 PM
