Spit & Sputter in the cold.
Only for you Carb Guys.
Do you ever have any issues with it Spitting & Sputttering?
Doing the enrichener/choke thing as the book states, also spoke to 2 dealers service deparments who say it may be a intake leak, jetts in carb to lean.
It does have a Stage 1 done to it, and the V&H Longshots, and it happens in the 30 40 50degree range.
For what its worth too, it gets better after about 40 mile of continnious running.
Any info/ ideaswould be great.
1 Post
RE: Spit & Sputter in the cold.
My friends sporty was doing that all the time and it was an intake leak. It stopped after he made the repair.
Both my bikes are carbed and I pull the choke out completely just to get the bike to fire then pull the throttle and push the choke in completely. I use the throttle screw to hold the engine rpm higher until it warms up. When I followed the manuals I would always get fouled plugs.
_____________________________
Chopper Hammer, I think I may pull the plugs tonight, and see whats up and start trying the throttle srew, Better know as the poor mans cruise control.
Thanks guys for the ideas.
Ride On........[8D]
Ride On........[8D]
when you pull the plugs, check them to see if they're white and dry / black and dry / or black and wet. this will give you an indication on if your mixture screw is set properly. another way to check for an intake leak, depending on your breather type, is you can pull the air cleaner and plug the intake hole with your hand or something, this should choke the engine and it should stop running... if it continues to run, you have a leak. another thing to look for is, when the stage 1 was done, did the mechanic just change the jets, or did he do the whole jet kit with new emultion tube / springs / jets and needle valve?
just a few more things to look into
This is the same exact way i start my Deuce
ORIGINAL: ChopperHammer666
Wolfdog - that's the exact set-up I'm running (Stage 1 with V&H Longshots) and yes, cold weatherdoes cause some sputtering and one cylinder operations for a short while. But never as long as you described. I would think that an intake leak would bea problem in all weather conditions.
It is also true that keeping the choke fully closed when cold starting tends to foul the rear plug and that is what is causing the hiccups on my bike. No big deal - call it personality.
Carbs rule!
[sm=icon_cheers.gif]
Carbs rule!
