Chirping sound since cam tensioner shoes
Could be an engine or exhaust pipe mount... a little rust that is squeaking at certain RPM's.
The new PCV vents work fine.
Is there a tunnel near you? Ride around in one and see if that helps you hear it at other RPM's or if that changes your perception of where it is coming from.
Good luck. Ride it until it breaks... seems to be the only way to enjoy riding a Harley.
I just started noticing a similar noise on my 05' FXST. The only thing I changed were the spark plugs. I plan on changing the header pipe and interconnect tube gaskets here in the next couple of weeks cause I know that they have worn out. I'll see what happens then.
I checked all motor mounts and took the exhaust heat shields off to eliminate those possible causes. It's definitely a new noise since I replaced the cam chain tensioners. I read on here to use a paper towel tube to try and isolate the noise. I thought this was hokey but tried it anyway. It worked to help me isolate the noise. It is coming from the rocker box. I could hear it and isolate it even in neutral.
The only thing I know to try now is to take the tank off and check those rocker boxes. I KNOW I triple checked everything when I put the top end back together and used a torque wrench to the manual's specs. I thought it was only from the front jug but the paper towel holder help me even hear it in the rear jug. In my test drives, it's still mainly noticeable at certain RPMs.
