Chirping sound since cam tensioner shoes
First of all, this forum is great. I've learned a ton here. Thank you.
I have an '04 Heritage I recently replaced the cam chain tensioner shoes on. I learned how to do it from here and all went great.
Since the install, there is an intermittent "chirping" noise that sounds like it is coming from the front of the bike but only at certain RPMs. I don't have a tach but speed is not the factor as it pops up in each gear at about the same RPMs. It is where the throttle is barely accelerated. It even sustains at that spot at high or low speeds and goes away if I totally let off the throttle or go beyond that barely throttled point. I cannot recreate it in neutral either. What could it be?
Thank you for any help.
You never heard this noise before you changed the cam chain tensioners?
Assuming that you did the tensioner(s) installation correctly the noises that you're hearing may be coming from another source such as the exxhaust gasket as previously mentioned.
Does your bike have the auto tensioner for the primary chain?
If not, you may want to check the primary chain tension.
Any chance that this is just due to the heat and your oil getting hot?
If everything looks OK, then you may want to pull the cover and take a peek a the cam chain tensioners.
The exhaust should get new gaskets when you take them off, especially if they have been on the bike for a while. There is a very specific two stage torquing sequence in the shop manual that should be followed to properly and evenly compress the exhaust flange gaskets. Some say that the SE gaskets do a better job.
C#
C#
C#
C#
Just one correction here. The SE gaskets should only be used when the header pipes are changed, and the manufacturer recommends their use. The stock crush gaskets actually seal better and a more forgiving.
Update
Ok, got the new seal and followed the 2 step process exactly and feel like I got a good even seal. I inspected the old one and looked like it was pinched wrong and there was even some soot in the crack where it pinched bad.
I took it for a spin to work this morning and still heard a little of the "chirping flutter" at the same rpm but a little different and not as sustained. I'm to the point now of thinking was it there and just didn't notice it? You know when you service something or do a mod and then your listening for a weird sound?
I think I'll still ride for a few more days and see if it still stands out. Thank you for your help.
It seems i read somewhere there was something with the clutch that could make this sound too. Anything else to check? I pinpoint the sound right in the center about where the crossover fuel line on the tank is.
Today
I don't need to ride anymore . . . . I ran some errands today before coming home. The sound is definitely there. As I shift through the gears, the sound comes and leaves at 20MPH, 30 MPH, 40 MPH, 50 MPH, and 60MPH. I still cannot recreate it sitting still. I listened real well coming home leaning forward and listening to the sides. It is not from the primary chain case or cam chain case. It is right in front. One thing I DO remember is when I did the cam tensioner install, the top end gasket kit came with new breathers. They looked different - no cap on top. The dealership assured me they were the new upgraded breathers. All holes lined up etc. Could they be making a different sound? Also, I notice, where the clamp holds the clutch cable to the frame in front where the adjustment is, the clamp is broken. It's just a plastic clamp I will replace. I doubt that is making the noise but I'm trying to give any information from that area that may help.
AJ
AJ
