Where to get power for GPS
I am installing a GPS on the handle bar of my 2013 FLSTC and want to run a power cable to it.
Where is the best place to grab the switched power?
I do not want to get into removing the tank to run the wires back to the battery but maybe that is not to bad.
I have opened up the headlight on previous bikes and got the power there, not sure if that is a good place on the Heritage.
Was wondering it I can get power at the switch for the driving lights?
Any thoughts would be great!
Thanks
Thanks
not sure if you're referring to the switch for the passing lamps but the orange/white should be an accessory feed and not tied into the passing lamp or headlight circuits.
I put a USB plug on the neck of the Deuce. Ordered on the Internet, it hooks to the battery with a fuse. I think it slowly drains battery, so I am going to move it to a switched supply. Worked good to power GPS and charge phone. I fished the wire under the tank without taking it off. I used the bicycle handlebar mount on the Garmin GPS I used.
I did something like that to my buell.. here is a link to the $8 Radioshack part that i used.
http://www.radioshack.com/product/in...ductId=3896268
Not 100% sure about a 2013 so you need to look. Under the tank you may find an O/W wire that's just dead-ended there. It used to be under the tank, left side, towards the front. I believe it was used for the International models that had a parking light. It should be hot in both acc and run so would be excellent for picking up power for accessories like yours. Take a look and see if you see the pigtail dead-ended under the tank (O/W wire with a connector on it but nothing connected). Someone with a 2013 FSM could probably look in the diagram for you.
Best of all, if it's there....free. No need to buy parts.
With that setup you just connect the negative to the battery ground post.. then take the positive and connect it to the power of your license plate lite or any positive side of a light that comes on only when the ignition is in the on position.
I went to Walmart & bought a weather-proof power outlet. Ran the wires down the frame on the right side & into the fuse compartment. As for the mount of the power outlet, I used one of those command strips that you can remove if you want it gone. I mounted it on the chrome plate behind the headlight & windshield. It was on there for 3 years but I took ot off this year as I installed a fairing that had 2 power outlets in it.. Very simple to do & less than $10.00 total.
