SE cam and cam tensioners
I did the upgrade on my cams when I did the 95" big bore I went with the woods roller chain conversion kit talked to Bob Woods and his kit includes everything you need for the up grade all bearings gaskets, and seals and it changes the rear chain to a roller chain also the kit sells for 620.00 and has everything you neeed except the cams I went with woods cams the TW 555 R or as its called the triple nickel woods cams are a little pricy they were 390.00 that and the 95'' pistons new lifters ported and polished heads and changed the stock ignition to Dyna tec twin cam ignition modual (bike is carbed) It now runs like hell bike is a 06 Heritage Classic
Andrews makes cams and chains to retrofit to the roller chain in the rear. They just got pushed out of offering the whole kit because H-D didn't want Andrews selling H-D branded parts. So if you get the SE plate and pump and front chain upgrade kit from H-D and the cams you want from Andrews you'll have the complete kit. $1500 is about what most dealers will charge to do this swap. I did mine for right about $900 including tools needed. I had never done it before and took about 5 hours taking my time and double checking.
