Jump-Starting a bike
Old Oct 14, 2013 | 06:45 PM
Sgt_Jim's Avatar
Sgt_Jim
Default Jump-Starting a bike
So.. it seems more often than it should that I come across people trying to jump start a bike.
My neighbor did it with his 2003 Suzuki something-err-other and tried jumping it to his car and wondering why the hell it didn't work and why he hurt his better more than it should (aside from the different cca's, they were both 12V batteries).
I always tell people who ask the same thing, Positive to Positive, Negative on the CHARGED battery, and ground the other negative somewhere else..
Anywho, I was looking for an answer to something else, and I came across this page..
https://www.harley-davidson.com/en_U...IL/file-7.comp
... well that's the entire thing.. but if you click here:
https://www.harley-davidson.com/en_U...dtopic000244-1
and scroll up just a hair.. the section on "Jump Starting" there pretty much tells you the same thing that I've been mentioning to people who never really believed me..
I just hope this helps someone out in the future.
Old Oct 14, 2013 | 08:07 PM
hdgzr's Avatar
hdgzr
Did it this past weekend just as you described; worked like a charm.
Old Oct 14, 2013 | 09:22 PM
langwilliams's Avatar
langwilliams
My understanding is just make sure the car isn't running. I've jumped a car off my motorcycle before.
Old Oct 14, 2013 | 09:30 PM
siege's Avatar
siege
I have jumped a bike before and found that while it got her started again it wasn't super effective at providing a lasting charge. Unless you have the car and cables right at hand, I'd just bump it and ride it.
Old Oct 14, 2013 | 09:58 PM
Tee&Vee's Avatar
Tee&Vee
dreaded sticky and i had to bump it.
YUP That ^^^
Old Oct 14, 2013 | 10:19 PM
wonson3's Avatar
wonson3
How about pushing the bike on gear then release the clutch while moving instead of jump starting?
Old Oct 15, 2013 | 05:39 AM
QC's Avatar
QC
That might work for a carbed bike, but not an EFI bike.
Old Oct 15, 2013 | 07:53 AM
JRuss's Avatar
JRuss
I've push started fuel injected VWs before. Is it different for a fuel injected bike?
I've push started my old carb'd sporty, but never had to worry about the fatboy yet (knock on wood)
Old Oct 15, 2013 | 10:16 AM
Warp Factor's Avatar
Warp Factor
Why not, as long as the battery has enough juice to run the electronics and fuel pump?
Old Oct 15, 2013 | 12:26 PM
JRuss's Avatar
JRuss
That's what I was thinking. Once the engine cycles it's producing an electric charge. So long as those components are good. If it's a manual transmission you should be able to push start it, in theory.
