Talked with JD...how hard is a Shotgun Shock install?
I am thinking about putting the Shotgun Shock on my CVO Breakout and I was wondering if the install is that difficult, or if anyone in the Chicago area has good info on a place to get the work done, or has done the job themselves.
After talking with JD for a little while, he made it sound pretty basic, but he wasn't 100% sure if the J&S jack was wide enough to do the install. I'm gonna call my dealer and pick their brains a little also.
It really is that easy. You don't need any special tools to do it. If you get stuck with a problem, ask this forum. Believe me, this forum will get you going. Or, just ask the man himself, JD. He's helped many forum members right over the phone. Good luck. It will be the best mod you will ever do to your bike...
I've never installed them myself. So I'll admit that upfront.
But I have to say I've seen multiple threads here where people are asking for help mid-install. So it can't be that easy for many.
And then I've seen a few threads of folks who have run into problems after the install and need help troubleshooting.
I don't say this to knock to the product. People obviously like it, and the installs ultimately work out, it seems.
But I really think folks tend to give optimistic evals of something when they have bought it themselves. I'd say expect it to be about 33 percent more difficult then people say it is.
Very easy, one to two hour install tops. Just pull the stock shocks mount the compressor mount the shotgun shock plug in and route some wires. I'm not sure where anyone could run into problems with it, the only hard part is breaking the bolts loose on the rear of the stock shocks, just hit them with heat and use hammer/wrench combo and they'll break loose.
If you (or your friend) are mechanically inclined at all it should be fine. It is not a difficult install just take your time and as stated above this forum can help. Do your homework and decide where you're going to put your switches then go for it! The install instructions are on the shotgun site. I'm pretty sure I remember someone doing a shotgun install thread. I did a quick search but haven't found it yet.
http://www.shotgunshock.com/instructions.html
