V-rod Wheel on Night Train
Old 09-13-2013, 12:02 PM
Alphadiver's Avatar
Alphadiver
Alphadiver is offline
Default V-rod Wheel on Night Train
Hi, I have checked this site for the answer before and cant quite get a solid answer, so...
I have an "07 Night Train with the standard 21x2.15 rim and 25mm axle (I believe), but want to go with a wider front wheel, the V-rod has the 19x3" (I believe), will this bolt right on? what is the axle/hub size of the V-rods?
Thanks, Mike
Old 09-13-2013, 12:52 PM
quan00's Avatar
quan00
quan00 is offline
It will not just bolt on... you will most likely have to move your primary drive out also which will require a little bit of work. Pretty sure the 240 wheel will not fit under the fender... not sure if that 240 will fit in that swing arm either... Checkout www.heartlandbiker.com and it will give some perspective on what you'll need (only an example of a 250 kit). That site also has the installation procedures to give idea...
Old 09-13-2013, 01:18 PM
JRuss's Avatar
JRuss
JRuss is offline
wait...
what wheel are we talking about here? front or rear?
I'm guessing front, but then this reply is talking about primary and swingarms.
Just wanna clear it up ha
Old 09-13-2013, 01:21 PM
Zakk13's Avatar
Zakk13
Zakk13 is offline
Im pretty sure he talking rear wheel.. I cant see a 240 up front on a Train..
Old 09-13-2013, 01:23 PM
_trooper_'s Avatar
_trooper_
_trooper_ is offline
^^this guy.....
Thanks, Mike
did not read this very well ^^
and op I don't have a clue. Sorry can't help.
ghoticov's Avatar
ghoticov
ghoticov is offline
Where did the OP say anything about a 240? lol
He is asking if a VROD FRONT wheel (a 19X3) will fit his 07 NT front.
I don't know the answer but not sure where you guys are getting the 240 rear talk.
Old 09-13-2013, 01:27 PM
Zakk13's Avatar
Zakk13
Zakk13 is offline
Ya for some reason i read the 2nd post myself! Dumb..lol As far as the front goes i think its going to be a fender issue..
Old 09-13-2013, 02:21 PM
Alphadiver's Avatar
Alphadiver
Hey guys, yeah I was talking front wheel (shoulda been more specific).
Anyway, if the fender not fitting is the only issue, then that's not so bad. Was expecting to go with an aftermarket front fender anyway. I'm more concerned with axle, brakes, forks etc. anything that might need major modifications.
Any help is good. Thanks!
PS - I'm gonna stick with the 200mm rear, but want to get away from the bobtail look and switch to a rounded fender, and good/easy aftermarket ideas are appreciated.
Old 09-13-2013, 03:50 PM
1004ron's Avatar
1004ron
1004ron is offline
I've read that the 2007 did not have the 25mm front axle - only started using the 25mm on the 2008.
Old 09-13-2013, 05:59 PM
back again's Avatar
back again
back again is offline
Received 4,904 Likes on 2,157 Posts
Good weed maybe.
Quick Reply: V-rod Wheel on Night Train
