08 night train with Cross bones wheels question
Old Nov 30, 2013 | 03:14 PM
Finmad's Avatar
Finmad
Default 08 night train with Cross bones wheels question
I am putting Cross bones wheels on my 08 nightrain and have a question/poll for you guys.
The wheels are from a 09 crossbones, the back is 25mm and I understand should line up fine. The front is 3/4 axle and my NT is 25mm up front. I am planning on removing the lower forks to have the powder coated. I also have a line on a new set of lowers already coated that accept a 3/4 axle.
So here is the question. do I stay with the 25mm axle replace the existing 3/4in barrings with 25mm and have custom spacers cut. OR do I replace the lowers with a set for 3/4in axle, get a new axle and spacer kit?
Old Nov 30, 2013 | 03:18 PM
ghoticov's Avatar
ghoticov
I am pretty sure the rear on your NT is a 3/4 and the front is the 25mm. Do a search on the forum though because there are differences in spacers you will have to contend with.
Old Nov 30, 2013 | 11:49 PM
1004ron's Avatar
1004ron
That would be the 2007 NT
I have just changed wheel bearings and can confirm that the front and rear are 25mm.
Old Nov 30, 2013 | 11:51 PM
1004ron's Avatar
1004ron
I think that it would be best to go with the 3/4 lowers to suit the 3/4 axle.
Old Dec 1, 2013 | 06:21 AM
Blk and Chrome's Avatar
Blk and Chrome
The '08s have 25mm bearings ft and rear. just change the bearings and use the right spacers.
Old Dec 1, 2013 | 08:38 AM
ghoticov's Avatar
ghoticov
ahhhhh...thats right. Its the crazy year, like mine. lol
Old Dec 15, 2013 | 08:09 AM
Prw3's Avatar
Prw3
Where you able to get the bones front wheel to work? always thought the hub offset/brake alignment wouldn't work since the CB springer front end brake offset/alignment is so much different then on traditional fork.
==ShaDoW==
Dec 28, 2014 08:30 PM
Prw3
Jul 30, 2013 05:30 PM
armorup
Dec 19, 2010 08:57 PM
joeyh76
Dec 17, 2008 01:17 AM
nevets61
Mar 29, 2008 09:59 PM
