Off center 22 inch wheel
I put a 21 inch front wheel on my deluxe its off center just a bit wIll that create any type of a problem other than looks.and why is the wheel Laist up so it is off center like that
What year bike? Some models came from the factory with a front and rear offset. Something about offsetting primary weight and aiding in straight line tracking. If it was a factory offset, the front fender should still be centered over the wheel, they just won't be centered between the fork tubes.
Might be correct IF it's the right wheel. As someone else brought up, many bikes come from the factory like that. My rocker is offset front and back...works fine because it was designed that way. Looks bizarre at first when you look close.
Does the brake rotor mount and work correctly? If it does, I would say you are OK.
Good luck.
Good luck.
