Air ride with cyclevisions set up??
I have exactly the same issue on my deluxe with RKC bags. It seems the backside of left bag touches the axle whenever the bike bottoms on road bumps and other irregulaties.
I am yet to find out a solution to this, so I'd be quite interested to see the responses of our fellow riders over here.
I had this same problem, the left bag had about an inch long gouge on the back side of it, directly above the axle. The cyclevisions kit instructions mention flipping the rear axle for certain year bikes. (Check and see if the nut for the rear axle is on the left or the right hand side of the bike). If it is is in stock configuration, the axle nut will be on the left. If that is the case, flip it and problem solved. That was all that was needed on mine to gain the clearance needed. Hope this helps.
I'll do some search around here to see how I can go about flipping the axle.
Thank you so much for the help...
Glad I could help. The axle flip isn't too bad to be honest. I was in the same boat. Put it together, saw it cleared, and decided to skip that step. Made a world of difference after the flip. No contact, even with the suspension fully compressed. Wish I would have taken before/after pictures to show you the difference.
Thank you so much.
