Need help...question
Old Jul 27, 2014 | 04:05 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Default Need help...question
Have done a few searches and can't find an answer, although I'm sure it's been covered.
My 2012 Heritage has drifted to the left (it's not road camber or how I'm sitting) since I first got it.
Had a new rear tire put on a few thousand miles ago and mentioned it at the time. Said they could find nothing.
Now with the new rear tire it is even more pronounced.
Is there anything unique to the softails that can cause this?
Gonna be checking forks and rear axle alignment....even though both tires are showing no abnormal wear patterns.
TIA for any help/ideas.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Old Jul 27, 2014 | 08:59 AM
jam436's Avatar
jam436
My '13 Slim has done this since day 1, and from reading here I'm far from being the only one.
It's nothing noticeable unless I let go of the bars, and even then it's slight enough that I can overcome it just by leaning a little to the right.
I'm guessing it has something to do with the rear tire being offset slightly to the left, about a 1/2".
There's been plenty of discussion about that here too, and I've yet to see a definitive answer as to why this is.
EDIT: Here's a straight on photo of my rear tire and fender - you can clearly see that the tire isn't centered under the fender...
Old Jul 27, 2014 | 09:02 AM
Sgt_Jim's Avatar
Sgt_Jim
There was a topic on this a few weeks back. It happens to almost everyone. I think the best (reasonable) answer is that the bikes just aren't 50/50 balanced. Something to do with the primary on one side and nothing to counter it on the left. I've had my tires tracked and trued, and it still happens..but like was mentioned, it only happens when i take my hands off from the bars.
And IIRC, the second best answer was "Well, keep your wallet in your right pocket.". Of course, I'd need a lot more money than I have right now to make a difference there.
donations, anyone?
Old Jul 27, 2014 | 12:22 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
I've heard both the above over the years, but was hoping it was not accurate.
I do like to take my hands of the handlebars now and then on the interstate on long rides (which is not possible with this drifting).
More importantly, when eating up the miles on a long trip, it does become a bit tiresome to keep constant forward pressure on the right bar to keep it heading straight. I have a bum left shoulder, so constantly pulling back on the left bar is not a good option either. (yeah, I'm an old fart...lol)
btw, in the corners and curves I don't notice it...it is only when I settle in on the relatively straight interstate for a lot of miles that it becomes irritating.
Could someone give me a link to the recent threads on the subject so I could do some reading up on it?
TIA
Old Jul 27, 2014 | 02:57 PM
Bone Doc's Avatar
Bone Doc
Kevin,
I have a 2012 Heritage also. Mine has drifted left since I got it. This is not unique to our year and model Harley. It is possible that true duals may exaggerate the drift but doesn't cause it. If I let go of the bars, I cannot compensate for the drift by leaning right. Since I have no undesired consequences (uneven tire wear) I consider it normal.
EDIT: Some threads below may provide additional information
https://www.hdforums.com/forum/searc...rchid=25697214
Old Jul 27, 2014 | 08:03 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Originally Posted by Bone Doc
Kevin,
Link is not working...what key words did you use in the search?
TIA
Old Jul 27, 2014 | 08:10 PM
Bone Doc's Avatar
Bone Doc
TIA
Sorry, Kevin. I didn't test the link when I posted it. Strangely, I had better hits by searching the Softail forum than I did with Google.
I searched "left drift" (without the quotes).
Old Jul 27, 2014 | 08:42 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Cool! Thank you!
Found some threads. Appreciate it.
Old Jul 28, 2014 | 03:26 AM
dandrumheller's Avatar
dandrumheller
Thanks for the links to other threads guys. Had been wondering about the left drifting tendencies of my new-to-me Deluxe, but was thinking it was something I was doing. Mine can be countered with some right body lean and a little adjustment off center of my seating position, but I wouldn't want to have to lean that far right for any length of time. Time to do some reading I guess.
Old Jul 28, 2014 | 09:12 AM
jam436's Avatar
jam436
Still the best way to search this forum is with Google.
The forum search tools leave much to be desired.
In Google, enter your keywords then add "hdforums" to the search.
ie; left drift hdforums
You'll get far better results.
