Rear tire alignment
Old 02-07-2015, 08:59 PM
StlJimmy's Avatar
StlJimmy
StlJimmy is offline
Default Rear tire alignment
This is my first Harley, and first post here. Forgive me if my parts description is off. I took my bike into the shop last year for the seal that goes between the engine and trans (oil and fuel mixed together and blew it out) and some carb work. When I rode it home it felt funny, like something was rubbing. Sure enough, it is rubbing on the rubber belt guard and very close to the frame. Tonight I adjusted the alignment by hooking tie wire into the hole on the swing arm and putting a mark on the tie wire to the center of the axle nut and adjusting the left side until the marks were even on both sides. This seems to make the rubbing worse. If I adjust it where the left axle bolt is further back, it brings the tire in away from the frame. I see that the rubber piece of the belt guard is bowed in. You can see a wear mark on the tire, just from a 10 mile ride. Is it possible a spacer or something was left off of the bike, or is the tire supposed to be this close to the belt and frame on the right side? Should I remove the rubber piece and leave the alignment as the book states, or make the alignment off to keep it off of the frame?
Attached Thumbnails Rear tire alignment-2015-02-07_195815.jpg   Rear tire alignment-2015-02-07_195820.jpg   Rear tire alignment-2015-02-07_195842.jpg   Rear tire alignment-2015-02-07_195913.jpg   Rear tire alignment-2015-02-07_200013.jpg
Old 02-07-2015, 09:07 PM
StlJimmy's Avatar
StlJimmy
StlJimmy is offline
another shot
Old 02-07-2015, 09:09 PM
John_K's Avatar
John_K
John_K is offline
Something is definitely amiss... what size tire?
Old 02-07-2015, 09:11 PM
RANGER73's Avatar
RANGER73
RANGER73 is online now
Received 5,962 Likes on 3,040 Posts
Just re read your post.
How much deflection in your belt?
You may not have it tight enough. as well as cocked.
I know my bikes different, but I don't have that guard there. I have a splash guurd in the front between the tire and lets say starter.
Riveted to the front of the fender.
Old 02-07-2015, 09:16 PM
John_K's Avatar
John_K
John_K is offline
Originally Posted by RANGER73
I take it you don't have a manual.
Take a stiff metal hanger, bend one end 90* about 2 inches up.
Take a tie wrap and put it on the wire, cut it leaving about 1 1/2 inches.
There's a small dimple on the swingarm bolt, hold the 90* bend in it. And move the tie wrap pointer so it's centered on the axle.
Without moving the tie pointer, get the 2 sides the same.
You have to go back and forth until the distances match.
Old School.
I use the swingarm bolts myself but he's measuring correctly... there are alignment holes on some swingarms for exactly that purpose.
Old 02-07-2015, 09:18 PM
dmg1029's Avatar
dmg1029
dmg1029 is offline
I would suggest letting us know the model of your bike and tire size. Was there any mods done by the previous owner (PO)? I make my alignment tool from threaded rod, then welded a large flat washer to a nut. That's my adjustable part of the alignment tool. The other end is just bent with a point ground on the end.
Anyway, welcome and let us know so we can help?
Old 02-07-2015, 09:22 PM
John_K's Avatar
John_K
John_K is offline
My bet is the tire's oversize and/or the spacers are incorrect.
Old 02-07-2015, 09:28 PM
StlJimmy's Avatar
StlJimmy
StlJimmy is offline
130/90 -16 is the tire size. I do have a manual and did just as you said, but I only adjusted the left side to match the right. The pictures are all with the mark matching and aligned as the manual states. I figured that they messed with the right side and adjusted it for the tension of the belt, and maybe didn't check alignment? These pics show the difference in space between the left and right side
Attached Thumbnails Rear tire alignment-2015-02-07_211656.jpg   Rear tire alignment-2015-02-07_212003.jpg
Old 02-07-2015, 09:33 PM
John_K's Avatar
John_K
John_K is offline
Tire size is good, they possibly... no, probably mixed up the spacers, measure their thickness and you should be able to tell right away if swapping them will correct the issue
Old 02-07-2015, 10:05 PM
StlJimmy's Avatar
StlJimmy
StlJimmy is offline
pushing up on the belt to show tension. Probably not the right way to demostrate
where the belt sits without tension
I am not sure where the spacers are? They did replace the ignition rotor, changed primary oil, engine oil, and I believe transmission seal. I wonder if they had the wheel off of the bike? It definitely wasn't rubbing before I took it in. There is about 5/8" between the swing arm and pulley the belt rides on
Quick Reply: Rear tire alignment
