Disconnecting Power with Smart Alarm II
Old 03-22-2015, 12:15 PM
hscic's Avatar
hscic
hscic is offline
Default Disconnecting Power with Smart Alarm II
When I do repairs/mods, I normally pull the main fuse to disconnect power. I had a smart alarm installed and now when I disconnect the main fuse, the alarm sounds. The Smart Alarm has its own battery pack so it does not need power from the battery to sound.
How do you'all disconnect power of the Smart Alarm to work on the bike i.e. change battery, lights, etc?
Thank you.
Old 03-22-2015, 12:51 PM
SLV's Avatar
SLV
SLV is offline
Turn the ignition on first, disarming the alarm, then pull the fuse while the ignition is on. My Dyna did the same thing. I about went deaf before I found a post and learned how toi do it.
I can't remember the re-install p[rocedure, but I think, when done, you'll re-insert the main fuse with ignition on also.
Old 03-22-2015, 04:25 PM
hscic's Avatar
hscic
hscic is offline
Thanks SLV....makes perfect sense although I would not have thought about that since disconnecting the fuse while the bike on and everything is live is kind of risky...and may spark when pulled.
Will try that the next time I need to disconnect power...thanks
Old 03-22-2015, 06:13 PM
hscic's Avatar
hscic
hscic is offline
Found this youtube video which shows you what to do for a Harley with an alarm system.
Remove main fuse with ignition on and replace fuse with ignition on.
Irndragn
General Topics/Tech Tips
07-11-2019 11:51 AM
Gitarded
03-11-2017 01:09 PM
hscic
Electrical/Lighting/Alarm
03-22-2015 06:16 PM
EasTexUltra12
12-20-2014 12:44 PM
Bandit17
11-22-2013 10:09 AM
Quick Reply: Disconnecting Power with Smart Alarm II
