Installed Biltwell Recoil grips on 07, 1200C
I installed some Biltwell Recoil grips on my 2007, 1200C.
I wanted a less expensive alternative to the $50-$100 complete grip replacements I see at some of the supplier sights. Searching around I found these Biltwell Recoil grips I liked the looks of. One of the install videos I found showed an easy install of these slip on replacements so I decided to give them a try. These were $17.95 shipped off that auction sight.
My throttle side grip was a pain but still only took about 15 minutes to get all the rubber off. The rubber was chemically welded to the plastic body and had to be scraped and sanded to get most of it off. The rest of the job took about 5 minutes.
Installing was a snap with an air blower. You just need a pointed blower you can direct air under the large opening lip as you push the grip on and it blows the grip up enough that it slides on. I didn't use any adhesive or lubricant to get them on and they are tight and secure.
AND here is a little video of the job.
I've had a set of them on for the last 10k miles and I absolutely love them. The bigger grip helps my hand fight fatigue and they're incredibly comfortable with and without gloves.
My wife has the white ones and she loves them ! I sprayed a bit of wd40 inside them to slip them on, was easy. They don't slip at all even though I used wd40. If they start to rotate on you, take them off, spray some hair spray inside them and put them back on.
Biltwel makes good products. I have the kung fu grips on my rocker and they are also supper comfortable.
