2 error codes , Iron 2014 .
Hi there , I have 2 error codes ...
First is P0113 : Intake air sensor high/open
Second is P0374 : Crank position sensor no passes ..
Anyone can give me some help on how to fix them ?
Iron 2014 .
Only different thing is the hammer air cleaner ..exhaust without baffles .standard.
nothing else changed on the motor ..
Iron 2014 .
On cars a high or open code usually means it's unplugged. Did you turn the key on while you had those sensors unplugged for the mods you did? Check the connectors then clear codes & see if they return.
