False neutral please help!
Old Feb 21, 2016 | 06:28 PM
Jasonsportster's Avatar
Jasonsportster
6th Gear
Default False neutral please help!
I have a 2003 sportster 883. I have been having problems with shifting. When cold it shifts perfect, but after a few miles and it gets warmed up, it will start shifting in between gears, and feels as if I'm in neutral. I have tried shifting every way possible so I know it is not my error. I adjusted my clutch probably 60 times, I put new fluid in it, tightened up my primary chain, adjusted on my linkage, and still not getting any better. Does anyone have any ideas? Please help!
Also, the timing was off causing shifting problems before, and I had that fixed a few months ago and everything was perfect till now.
Thanks Jason
Old Feb 22, 2016 | 02:18 AM
JustOneDean's Avatar
JustOneDean
Sounds like worn gear dogs. Is it more noticeable on acceleration?
Old Feb 22, 2016 | 05:53 PM
Jasonsportster
6th Gear
It is in predictable when it will happen. When the bike isn't warmed up yet, it shifts perfect. Thanks for the input! I am about to tear it apart.
Old Mar 4, 2016 | 09:37 AM
Zanthamos's Avatar
Zanthamos
I would check the clip and pins in the shift drum. There is a problem where the pins would work themselves out of the shift drum breaking the clip that holds the shift detent plate in place. The fix is simple, pull out the pin and use #263 thread locker on it then tap it back in with a brass punch. Then check the shift linkage adjustment according the service manual and reinstall the clutch hub.
Old Mar 5, 2016 | 08:29 AM
grbrown's Avatar
grbrown
Before you tear it apart, try to establish what the actual problem is! This may be one of those occasions when a visit to a local indy will prove useful, for an independent and expert opinion.
Old Feb 10, 2020 | 06:51 PM
WinstonC's Avatar
WinstonC
6th Gear
Did you ever find the solution to your problem?
Old Feb 10, 2020 | 07:02 PM
Jasonsportster
6th Gear
Default Help
The star looking thing to the right was loose not letting it fully engage in gear
Old Feb 10, 2020 | 09:15 PM
WinstonC's Avatar
WinstonC
6th Gear
Where exactly is that?
Old Feb 10, 2020 | 09:36 PM
Jasonsportster
6th Gear
Behind the clutch basket. Its not very difficult. But 1 good thing to know is that the nut for either the clutch basket or stator is reverse thread. I forget which one now. I put block of wood between the chain and sprocket to keep it locked down instead of spinning the motor. Use lock tite. (Made that mistake once lol). Clock the star right and put that c clap back on it. Then CLICK THROUGH ALL THE GEARS AND MAKE SURE ITS CLOCKED RIGHT BEFORE PUTTING IT TOGETHER. Made that mistake once too lol
Old Feb 10, 2020 | 09:50 PM
TriGeezer's Avatar
TriGeezer
This is a weird thread.
