Evolution diamond termintor or barnett scorpion or extra plate clutch pack?
On. 2013 stage 1 1200 sportster. Is it worth going with a full clutch kit like the terminator or scorpion ? In the long run? Or does a 80hp+ sporty not enough power for those? Or is the energy one extra plate kit more then enough? The diaphragm is just lame i love the idea of the 5 springs like in my dirt bike. There is also a small chance ill do cams way down the road.
The stock Sportster clutch is similar to a big twin clutch, in other words it has a healthy safety margin in it! Recent Sporties also have a better design of clutch than my old Evo 1990 big twin, in which I have an S&S 107" engine, with just over 100/100. I have just replaced the original plates with a Barnett clutch +1 plate set, although it's early days yet to comment on it. I did consider a complete clutch replacement, but two local indies said it isn't necessary and the saving on my pocket won the day.
I put a Primo Rivera +1 HD in mine, there again with the 1200 kit it kind of needed it. I'm more than likely going to need to upgrade this one eventually once I figure out cams and what not. If you are thinking of extensive motor work then an upgraded clutch down the line may be a good thing to add to your list, but unless it is slipping or currently needs replaced then you should be fine for now
I don't think that H-D do, unless they sell an SE kit, but firms like Barnett do, which I have. Available here in the UK as well, got mine from JC Motors in London, but there are others.
Mr_Taipan (06-08-2016)
my question is to switch from the stock diaphragm spring plate. to a full billet basket with 6 coils springs. am I going to get any issues with drag with a scorpion or will i just have a strong clutch, harder pull, but same engagement feel.
In the case of my Glide, I've gone from a stock engine to a tuned build, then to a fresh bigger engine, from roughly 50HP to 80HP to just over 100HP. I needed a beefier spring for both the 80 and 100 builds, so I suspect whichever clutch option you choose to go with you will have a harder pull. I can't see any reason why any clutch change will introduce drag.
