Rear brake caliper removal on 99 sportster 1200 custom
I have both pins out and can get rear brake caliper 1/2 off but not any further. It has to be removed in order to replace brake pads. Any advice would be greatly appreciated. Haven't had a chance to purchase owners manual yet but will definitely be doing so very soon. Thanks
I just relocated and replaced my rear caliper to accept a larger rotor....It was so much easier without the rear tire.
After everything was installed, I also forgot the grease the pins on the floating caliper so removed the pin bolts and slid right off.
Ya I have the pins pulled but it would only slide 1/2 way then it's like something is holding from going any further. I don't have a bike jack yet so the tire removal is not an option at this time but will be adding 1 very soon as I don't like the hard concrete floor and having it off the ground would make life alot easier for sure. I will be trying the putty knife in the morning and hopefully that will give me the needed room to either slide the caliper off or to get a screwdriver in there to spread the caliper enough to remove it and complete the task at hand . Again thanks for the advice and other options to go with
Hope that works for you. Not familiar with a 99 but on newer models, brake pads can be changed without removing the caliper. You just need to remove the pad pin plug and pad pin and the pads will just drop out. There are several youtube videos on how to replace brake pads.
Not sure if you are familiar with brakes so just in case....you will need to pump the brakes a few times to re-engage the pistons after you install the new pads and the caliper is back in place.
hscic (08-02-2016)
