Harley Vets I need some help! Error codes P0151 P0152 & P0154
Old 10-04-2016, 11:55 PM
devildawg712's Avatar
devildawg712
devildawg712 is offline
Originally Posted by Guzzi
Have you tried putting your original tank back on to see if the bike performance improves?
What tank did you put on and is it factory or aftermarket?
Does sound like it's electrical or vacuum related.
I threw an aftermarket 4.5 sportster tank on. I went thew at at least 5 entire tanks before I brought it in so it couldn't of been the gas. I don't think they tried to the old "peanut" shaped tank.
I honestly don't know what an "electrical" issue would sound like but it definitely sounds like its not getting the proper fuel. Throttle seems like its being revved at low RPMS at times. backfires and all the nasty symptoms. I'm sure the wizards Dudley Perkins will sort it all out.
Old 10-05-2016, 12:53 AM
JustOneDean's Avatar
JustOneDean
JustOneDean is offline
The "breaker box" is a Harley specialty tool, the "breakout box." It's basically a box you hook up to the bike in one connector. The box has a lot of small, numbered connectors in it that you can use to test and isolate certain circuits without having to go and find individual connectors and wires in the main harness. Usually only Harley dealers have them. They're pretty expensive.
devildawg712 (10-05-2016)
Old 10-21-2016, 05:52 PM
devildawg712
Happy to report the bike is back to running normal and even BETTER than before. The boys at Dudley Perkins are awesome.
Since I wasn't getting any error codes they literally started at one end and had to go through the entire bike. It ended up being bad fuel injectors. All other symptoms that normally any mechanic would go through ended up not panning out given the indicating symptoms.
Woohoo Thanks for all the help.
Jrotten65
17
01-26-2022 08:34 PM
redsox
11-07-2018 07:08 AM
bdtaylor1979
04-10-2016 12:40 AM
nupicasso
Exhaust System Topics
03-07-2008 10:42 AM
nupicasso
03-07-2008 10:26 AM
Quick Reply: Harley Vets I need some help! Error codes P0151 P0152 & P0154
