Brake Install Help???
Hi all, picked up a Wilwood GP310 caliper to replace the stocker on my 98. (Wilwood says it's direct replace for 99 and down). I also purchased a brand new Magnum brake line.
Question is - the new caliper says to use DOT 3, 4, or 5.1 only, but my stock master cylinder says only use DOT 5. I know you can't mix, but if I flush out the stock master, can I use a different brake fluid? Or is the master really only designed to only use DOT 5?
lol up Google
If it was me I'd contact Wilwood and ask if I could use DOT 5 - they have an email address for tech support (customerreply@wilwood.com) and a phone number (805 388-1188) on their site.
I know this is an older thread but I was searching the forum looking for info on if DOT 5 should be used in Wildwood GP310 calipers. This thread was the best I could find but there really wasn't an answer from the manufacturer. Here is what I found from Wildwood:
https://www.wilwood.com/PDF/NewProdu...08_Harleys.pdf
Gregg
Gregg
I've had a Wilwood GP310 for over two years now, using DOT 5. No issues at all. I don't recall seeing anything about using 3, 4, or 5.1. I don't recall any instructions at all, just the caliper in the Wilwood box. So, I just used what I always used, DOT 5.
I would assume the Wilwood engineers are aware that most Harleys use DOT 5, at least in the 1990's.
John
John
Gregg
Gregg
Note what Wilwood says: "Harley-Davidson Motorcycles specifies use of DOT 5 silicone brake fluid because [reasons]. Wilwood disc brake calipers will work with either fluid, BUT NEVER mix DOT 5 [with any other type]."
I've been running GP310's on my 1990 for years with DOT 5. No trouble at all. And a huge performance improvements compared to the stock calipers.
With an older bike, it is best to test your fluid, rather than assume that no one put in the wrong stuff over the years. Easy to do. Take a small, clear jar (a baby food jar is perfect). Fill it half way with water. Take a syringe (any pharmacy will give you one) and pull a half a teaspoon or so of fluid out of the master cylinder. Put it in the water and shake/stir. Give it a moment. DOT 5 won't mix with water. Any other type will.
Gregg
Omaha Derby Covers (12-28-2022)
