Wheel weights?
Old 04-25-2017, 09:19 AM
TStephen's Avatar
TStephen
TStephen is offline
Originally Posted by Gil Aguilar
Thats pretty cool stuff! I talked to someone about it. I talked to a tire tech about it. He said the down side of it is that in cold days its going to be solid inside and will take a while to heat up, cause my motorcycle to shake. And probable more so that i have a lighter framed sportster. Hmmmm. I was really thinking of getting it. Now im torn.
Amazing how many experts there are out there eh?
I believe it becomes a gel like substance once it "cures" and it doesn't move around in the tire any more after that. The effective temperature ranges have to do with the sealing ability, not the balancing effect.
But I'm no expert.
Old 04-30-2017, 02:30 PM
Gil Aguilar's Avatar
Gil Aguilar
Gil Aguilar is offline
I took the advice of getting this stuff. I ordered the 3 pack from the link provided. So i will be putting it in when i have a day off
Im a little confused on a couple of things. 1. Is the tires metric or standard? Im thinking standard but im not to sure. 2. Is the the tires tubless or have a tube? 3. According to the chart above my tires size would be what?<br/>Front tire: 90×54×21<br/>Rear: 150×80×16<br/>.....to put in the calculator? Just unsure on those things. But putting the stuff according to the video seems pretty easy!
Old 04-30-2017, 03:02 PM
TinCupChalice's Avatar
TinCupChalice
TinCupChalice is offline
Received 8,749 Likes on 3,962 Posts
http://www.ride-on.com/images/storie...april-2012.pdf
Ride On recommends a 25% increase to the severe dosage level if you're using Ride On for balancing without wheel weights or using it in tubed tires. Running without weights or if your tires are tubed just follow the severe dosage recommendations.
http://www.ride-on.com/calculator.html
Select 'motorcycle' in vehicle type and put in the tire sizes and hit 'calculate'.
Your front is an MH90-21 which is the same typical size as an 80/90-21. Following the dosage calculator that would be 6 ounces.
The rear is a 150/80-16; again in the calculator that would be 11 ounces.
Install, remove the wheel weights, clean off the residue from the wheels and enjoy...
Old 04-30-2017, 03:06 PM
cvaria's Avatar
cvaria
cvaria is offline
Received 2,189 Likes on 1,677 Posts
The goods! You will love it and you now have moderate flat protection
Old 04-30-2017, 07:31 PM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,237 Likes on 1,813 Posts
Whoa fella...I hope you don't mean what i think you would mean looking at the entire photo and reading your words...but to each his own
Old 04-30-2017, 08:58 PM
Gil Aguilar
How did you get 80/90-21? Im not sure how to calculate mh90 21. It doesnt have a 3rd number to compute into the calculator. And im not sure if its metric or a standar tire. How do u determine that? And still unsure of the tube or tubless thing as well.
But i thought if i should retake a pucture of that ride on but didnt think to much into. Didnt think anyone would point something out like that, but i guess i was wrong lol
Old 04-30-2017, 09:25 PM
multihdrdr's Avatar
multihdrdr
MH=80mm "metric" (used in an Alphanumeric system)
So, MH90-21 = 80/90-21
If you see a MJ90, it's 90/90 (out there looking for tires)
It's a "TL" Tubeless tire that can be run with a tube
https://www.revzilla.com/common-trea...ires-101-guide
Old 04-30-2017, 10:25 PM
BlackBettyXLC's Avatar
BlackBettyXLC
BlackBettyXLC is offline
MH90-21 is the same thing as 80/90-21. If you have the 21" spoke wheel that comes standard on the Sportster 72's, then there is a tube in it. Spoke wheels require a tube.
Old 04-30-2017, 10:32 PM
multihdrdr's Avatar
multihdrdr
is there an echo in here?
Old 05-01-2017, 11:48 AM
Gil Aguilar
Ok thank you very much! Both of your advices are very miluch helpful. So i now know its metric and a spoked rim requires a tube. And yes i do have tge sportster 72. So does that mean my back tires is metric as well? So i can put it in the proper calculator
Quick Reply: Wheel weights?
