What should I do about my bent frame?
RE: What should I do about my bent frame?
Hate to tell you guys this, but if you're riding a Sporty, and have ever bottomed out in a pothole, your frame is probably bent.
Received 1,211 Likes
ORIGINAL: 1200c
Do you have to bottom out in a pothole or just bottom out? Because as you know the new rubbermount customs have problems with bottoming out. So if you had a passenger on there and the shocks bottomed out you have a bent frame?
And frame repairs can be done with no worries they'll be the kiss of death (literally) to a bike. After all, a frame started out as pieces of tubing, castings, and forgings. All these pieces are drawn, bent, welded, machined, stressed, etc. If it's done correctly, the frame is good. Same thing with frame repairs.
ORIGINAL: Thumper26
So how do all these potholes, suspensions bottoming out, etc. affect the hardtails?
Thumper26
Thumper26
Years ago we used to put struts on Sporty frames to lower them as far as possible. I made my own struts, as well as buying some. After riding the bike for a year I wanted to tear it down and paint it. I found paint had flaked off around the upper shock mount area. Did a spot check for cracks and found several. Measured the frame and also found it was bent in the same area. Being curious my buds and I started looking at our other Sporties. Every one of them, both strutted and those with shocks, were out of whack at the upper shock mount area. Years later I mentioned it to a guy who straightend bike frames, fork tubes, springers, and girders when I crashed a beautiful Fury girder front end. He gave me two pieces of bad news - my Fury girder couldn't be fixed, and all Sporty frames were bent. He also said that most every motorcycle frame was tweaked somewhere, and that it was usually not noticeable, unless the frame was on the table.
I always look at how a bike tracks by running through water, then onto dry pavement. Doesn't show much unless the frame is seriously tweaked, but makes me feel good. Also look at the bike from low angles, head on and from the rear. Look for wheels that are canted from each other. Some models have the front and rear wheels offset from each other and/or the centerline of the bike, so you need to know what to look for. Obviously, eyeballing a bike ain't an exact science, but you'd be surprised what you can see.
Poco,
Thanks for all of the great info....
Update on my frame:
I am replacing the frame and the local HDealer is doing the work....
Since I am going to have the frame stand alone I am going to have it powder coated the same color as my tank which is glacier pearl
My plan is to have some flames or some graphics painted onto my tank
Thanks again for everyone's posts!!
Update on my frame:
