My bobber build
My bobber build
I finally got started on my build after buying my 93 883 years ago. I went with a Kraft Tech frame 3 inch up-1.5 backbone stretch-34 degree rake with a 200mm tire. I went with a 23wheel for the front and 18 wheel in the rear, waiting on my springer front end to come in. Here is a pic.
Received 3,963 Likes
Looking great so far. Gonna keep an eye on this thread to see where you go.
I am, ever so slowly, working on my own hardtail build right now.
__________________
Kevin
Gear Up & Ride in! DK Custom 4th Annual Open House, June 8th. 🏍️ Click HERE For The Lowdown.
DKCustomProducts.com
Kevin
I had to order a new rear sprocket with countersunk bolt holes so it will clear my frame when the wheel is centered. I also had to order longer springer rockers so i can clear the front hub it was close but no cigar. I also ordered tank and seat and other small items. I did get in my threetwochoppers front hoop kit for my dna springer. I should get some more mock up done this weekend.
I got the new sprocket in and installed,centered the tire and started working on the brake caliper frame mount. I am just waiting on the chain now to make sure it clears the tire and frame before moving on. There is not much room in the rear i just want to make sure its all gonna work the first time.LOL
