Help me kick start
Help me kick start
So I'm 17 yr I'm 5'5" and I weigh probably around 120. I have a 1979 sportster xlch kickstart only. It was my dads first bike and I would rather keep it then sell it. My father( a relatively big guy) can kick it three kicks no problem and it starts. But when I try I always get a kick back or sometimes I can't even kick the lever down( kinda like it gets stuck ). Anybody have some helpful hints for me? Or some advice on a possible electric starter ?
Wish I'd have watched those videos when I had my '74. I couldn't count the number of times the kickback hyper-extended my knee... sheessshhh it's amazing my leg still works at all!
I did get in the habit of jumping on it with my whole body weight, and that seemed to work much better for me. But I knew there had to be a better way.
In closing x2 on checking some of the youtube vids. One of them will surly help you.
Perseverance will make all the difference....don't give up. You will feel it when it's primed. At that point, give it all your weight
Check out this vid...same issues you are having but persistency made the difference. No offense intended but just wanted show that you can do it....just make sure your bike can start i.e. good plugs, clean fuel, clean carb, functioning throttle, etc.
Good luck
Good luck
rv7garage (08-08-2017)
My process, one or two kick start every time:
Ignition off. Two squirts from accelerator pump. Two kicks through to prime.
Ignition on. Throttle closed with choke all the way on. Kick hard and fast.
https://instagram.com/p/BUsiRYDg9NJ/
Also, you should get the pistons close the bottom of the compression stroke. This is easier said than done. Before you follow above advise, try to kick the crank over until you feel resistance, this should be at bottom of the compression stroke. Have someone show you if possible.
When you kick it, keep your knee a bit bent as you use your body weight on the kick starter, then just before the kick starter hits bottom, straighten your leg for that little extra oomph. Kind of breaking your wrists at the end of a baseball swing. The kick starter will not kick back if it's at the very bottom. Concentrate on kicking it all the way through its stroke to the bottom. A well tuned bike is a lot easier to start than one that is out of tune.
Good luck, you'll get it soon.
Ratwerke (08-07-2017)
It's all about technique and despite your dad being a big bloke, he has it so should be able to pass it on you! Having been riding for over 50 years many of my bikes have been kick start, including a shovelhead, and personally I would stand astride the bike, not alongside it - that just looks cack-handed and awkward. The poor lass in that video above is being badly taught IMHO - don't try that way!
Good advise here.
