Hot negative terminal post on battery?
Old 08-10-2017, 08:37 PM
mlrailguy's Avatar
mlrailguy
mlrailguy is offline
Default Hot negative terminal post on battery?
My bike didn't want to start this morning, acted like dead battery. Got home, after work, and began to pull battery out. Removed + cable, pulled battery out, and began to remove - cable. I then noticed how warm the cable and post were, almost hot. This can't be normal?
Old 08-10-2017, 08:46 PM
81rat's Avatar
81rat
81rat is offline
It telling you there's a short somewhere and coming back to the battery , or maybe something simple like loose or corrode cable ends
clean every cable and wire end that you can (everywhere ) even at breakers and then see if cable still gets hot
Old 08-11-2017, 06:51 AM
mlrailguy's Avatar
mlrailguy
I had just recently cleaned all terminals and ground lugs. How do I clean the breakers?
Old 08-11-2017, 12:48 PM
TStephen's Avatar
TStephen
TStephen is offline
Warmth means resistance which is usually caused by bad connections/corrosion and/or bad cable. It's possible the strands inside the cable have broken over the years. There could be corrosion at the crimp under the insulation. Etc....
If the clamp/post looks clean, and the ground on the frame at the other end is good, I'd replace the cable (not expensive) and see what happens.
Old 08-12-2017, 02:03 PM
mlrailguy's Avatar
mlrailguy
cables are all new last fall
Old 08-12-2017, 02:10 PM
QC's Avatar
QC
QC is offline
Received 19,788 Likes on 9,863 Posts
How old is the battery?
Old 08-12-2017, 04:25 PM
Ratwerke's Avatar
Ratwerke
Ratwerke is offline
Two alternate ideas:
Post and cable next to hot oil tank?
Or, internal damage to negative post.
Just throwing these out there.
Old 08-12-2017, 05:19 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,531 Likes on 4,631 Posts
Always remove negative cable first, connect negative cable last.
The cable is hot due to a poor connection.
Old 08-14-2017, 11:22 PM
mlrailguy's Avatar
mlrailguy
Positive has to come off first in order to slide battery out far enough to get to negative cable. Another blunder on HD's part. All cables are new and heavier than original, battery is new also. This has been an ongoing problem since I've had it. This was the first time tho, I noticed how warm neg. terminal was. Seems to be good a few weeks then suddenly no good any more. I did find a bare wire going back to rear turn signal, not sure if it was pos or neg. Also, the horn has never worked, maybe something there?
Old 08-15-2017, 08:56 AM
deadrubberboy's Avatar
deadrubberboy
deadrubberboy is offline
Year/make/model? Some years (2007 is notorious) have electrical issues in the relays.
Quick Reply: Hot negative terminal post on battery?
