Screaming Eagle 1200 kit question
Hey everyone, perhaps a dumb question but I will ask it anyways.
I have this kit on my 2017 Iron (minus the intake, I have a Joker Machine). Would this kit be the exact same engine you would receive on a 48 or other factory 1200 Sportster? I'm not asking for "better" just curious if there are any differences. Cheers
Received 2,189 Likes
yes, outside the air cleaner same set up.. same kit i used on mine (30003-10):
https://www.hdforums.com/forum/sport...l#post11183436
i think the recent sporty 883s have have similar or the same gearing as 1200s.
TimmyPage (09-05-2017)
copied directly from harley-davidson website:
2018 forty-eight
Primary Drive Chain, 38/57 ratio
Gear Ratios (overall) 1st 9.315
Gear Ratios (overall) 2nd 6.653
Gear Ratios (overall) 3rd 4.948
Gear Ratios (overall) 4th 4.102
Gear Ratios (overall) 5th 3.517
2018 Iron 883
Primary Drive Chain, 34/57 ratio
Gear Ratios (overall) 1st 10.41
Gear Ratios (overall) 2nd 7.436
Gear Ratios (overall) 3rd 5.531
Gear Ratios (overall) 4th 4.584
Gear Ratios (overall) 5th 3.931
gears are not the same
2018 forty-eight
2018 Iron 883
Interesting, as H-D used to use the same primary and different front pulley. As Cvaria points out the secondary is now the same on both 883 and 1200 models. Wonder why they made that change?!
I've read it here a few times, and have to ask, what's with the Short Shots hate on this forum? Most 883s I see for sale locally, with upgraded exhaust, have Short Shots, so its obviously a popular product.
I have Big Radius and TTS Mastertune. Still need to dyno it as I'm getting a lot of decel popping after the conversion.
Thanks for that gear info.
I'm quite happy with it so far. The motor doesn't really care what gear it's in now and just goes.
