Sportster 1200 elevated jetting
I just bought some straight pipes for my Sportster 1200, I already have a screaming eagle air intake. I know that I'll need to go down a size on the pilot jet and up a size or two for the main. However, I'm unsure of what I'll need to do for the needle, air to fuel ratio screw and apparently there is some sort of spring that I am unfamiliar with and it improves throttle response. I live in Utah, so elevation of 4,550 feet will effect it all. Any advice on what to do? Thank you in advance!
The place to start is to remove and identify your existing jet sizes, the very small numbers are stamped on the end of the jets. You'll likely need a magnifying glass.
