Questions about Valves (w/ Intake and Exhaust pics)
I posted a separate thread about my piston tops and the deposits that had built up over the last 17k miles. In this thread, I'm posting some observations and questions specific to my bike's valves, as this thread title states. Below are some pictures of my rear head and its valves. As you can see, my exhaust valve face is very pinkish white while my intake head is a bit more sooty. I also observed that the same can be said of their respective valve stems. The exhaust valve stem is pale and ashy while my intake stem is a wee bit gunky and dark.
One of my assumptions is that the dark appearance of the intake valve stem and face is due to the hot oily air that used to be re-rerouted back into the intake (before I purchased an external breathing system), which led to the intake valve chamber becoming oily as the hot gunky air stuck to its walls. In the intake valve picture(s) below, you can see that the hot oily air followed the path of least resistance from the intake as it made it's way to the valve chamber, eventually leading to it getting stuck to the far wall and the valve stem before entering the combustion chamber. I'm going to be running some various intake/fuel system cleaning procedures to see if it helps get rid of the deposits built up in the intake valve chamber; additionally, my hope is that it leads to the break up of carbon in the combustion chamber itself.
My other assumption, based on some light research, is that the white appearance of the exhaust valve stem and face is due to a hot/lean condition. Below you can see a couple of pictures of my plugs and their condition. The only fuel enrichment device I currently have is the XiEDs (have run these the past 8-10k mi). I am running Cycle Shack slip on exhaust (no baffle, DK TTIs) and a Hammer Performance intake (have run this the past 10k mi).
My questions are as follows:
Front intake valve chamber
Rear intake valve chamber
Rear exhaust valve chamber
Rear head valves
- Do these valve conditions seem normal given the circumstances and mods? If not, what are some remedies/preventative maintenance?
- Do my assumptions seem to align with the facts about valves and their condition on these bikes?
Rear head valves
Your plugs look good and normal. Thank the damn EPA for the breather's oil air entering the intake tract. I ran XiDED's in my 07 Dyna for a few years until I converted it to a CV-40. Clean up the ports and valves real good. You have already taken care of the oily intake air problem.
Anyone else have some valuable input/experience?
I have used it to remove other oils/gunk/deposits, but I did not try in this application. I used carb cleaner and let it soak for a bit before scrubbing with a nylon bristle detail brush and then using a razor blade for stubborn stuff. It worked well for most of the flaky dry crap, but it didn't do too well on the gunky oil build up in the intake. I'm going to see if some Redline fuel system cleaner can do some work on that stuff.
You can get a can of either Gumout or CRC cleaner, make sure they have PEA. Pour accordingly each fuel up and you’ll be good. Use the stuff on my 15 Iron and 01 XJ Cherokee with 180k miles and cleaned the crap out my valves and piston heads. Autozone usually have the gumout at but one get one free for like 8 bucks, one can will last a while for the bikes fuel capacity.
Truth is hard to come by as most people really don't want it.
To get an honest assment of the AFR install a simple wide band such as AME . They are the best tool you will ever buy!
Valves spark plugs as to what the forensic look like, - is dictated by the last few seconds it was running as it all changes very rapidly in there.
Knock your vales out and show me the seats and margins.
You might as well make some improvements whilst apart.
Dont clean them yet.
Update: I took some time to clean my bike's valve chambers today. I cleaned them while the heads were still on the bike. It was a bit of a PITA, but it worked out pretty well. I used MAF cleaner since it cuts the crud pretty well but is not as harsh of a solvent as others.
First I would spray the cleaner in the intake chamber. Then, using a vacuum, I would suck out any excess that was puddling. Then I would take a small brass wire brush and scrub the gunk really well until it broke up. Finally I would take the vacuum and suck out any crud that had come off while cleaning. I repeated this process a few times on each head. My next course of action is to use the Redline fuel system treatment to see if it will clean up the valves/pistons even further. Here are the results:
Before:
After:
Before:
After:
