Show off your XL's
  #81
Old 02-14-2019, 12:40 AM
Boomer66's Avatar
Boomer66
Boomer66 is offline
Stage II
Default 2006 xl883l
going on with my second season of riding.
  #82
Old 02-14-2019, 07:59 AM
MikeK13's Avatar
MikeK13
MikeK13 is offline
Originally Posted by Artax
like I said earlier I should just make a post. but I will answer here since you asked.
I used abs plastic, for one reason it takes heat better so being outside in the sun isnt an issue, pla is not good for heat. second you can glue together abs with abs juice/glue/slurry or whatever you want to call it. basically acetone/abs mixed. the acetone melts the abs then you can use that to glue abs parts together. the outer fairing was made in 5 pieces and inner was also 5 pieces. Glueing and alot of sanding and filling with abs glue. The outer fairing does have a layer of fiberglass resin done by the body guy/painter before final painting was done. There are downsides to abs, biggest being the warping of parts in the printing process.
The design was all done by me, the entire project probably has a couple hundred hours of design time. It went in stages as I changed the design as I originally designed for different speakers. I use PTC creo for all the design work.
Again, really nice work. Thanks for the reply and i look forward to seeing your post on the work you have done
  #83
Old 02-14-2019, 10:46 AM
Dudepants's Avatar
Dudepants
Dudepants is offline
Nice clean whip there man, love it!
  #84
Old 02-14-2019, 03:20 PM
TStephen's Avatar
TStephen
TStephen is offline
Originally Posted by Andyp247
I absolutely LOVE the look of this bike.
One question, where did you put the billboard that passes for license plates in the UK? I thought they had to be back and centered.
  #85
Old 02-15-2019, 09:55 AM
AMP'd's Avatar
AMP'd
AMP'd is online now
New guy here. Been lurking, reading and researching for a long while now. Just recently finished up my winter makeover and wanted to share with some people that might appreciate the work put in. Here is my 2010 48. Not sure what to call it yet, maybe fat 48 sporty glide lol.
Game over, you win.
Looks great bro, the hard work you put into that is evident.
Artax (02-18-2019)
Bristolz555
Touring Model Pictures
06-05-2018 07:45 PM
cmashark
04-19-2018 12:00 PM
Quick Reply: Show off your XL's
