Would 2014 Iron Front fork fit 2018 model?
research yourself.
http://partsfinder.onlinemicrofiche.....asp?make=hdmc
I -think- the external tube/slider are the same, but the "guts" on the new models are probably better. ie) cartridges
hth,
T.
RiverSouth (01-17-2019)
WKNDS
I knew about microfitche and looked it up before I posted here, but FYI, same parts use different part numbers on different years. Maybe someone can confirm this for you.
gbrown, new set of shocks are closer to 800 bucks, and mine are damaged and need replaced. There are some slider and tubes in the market in good shape, and considering the nature of the parts I could save 600 bucks just by buying used. by Nature of the parts I mean a slider is just one solid piece of metal and as long as its not damaged or scratched it will perform just like a new one. The inner spring is cheap and can be upgraded later.
Now, I still dont have a definitive answer. Specially on brackets
WKNDS
I have not seen "the same part" with different part numbers, but I HAVE seen in the microfiche where
old part numbers have been identified/updated with the new superceeded part numbers.
So back to the microfiche, as I suspected, the 2018 Iron uses newer cartridges so it will have better "action" than
the older 2014 Iron system. Will the older Iron forks "bolt in", yes since the tubes are still 39mm. Just don't expect
the ride/suspension action to be as good as the newer Iron version.
good luck,
T.
No one can answer your question because we do not know what 2018 model you want to use 2014 Iron fork parts on.
The 2016+ the front forks have a cartridge in one side, the 2015 and earlier are damper tubes in both fork tubes.
For 2018 there are five sets of upper/lower fork brackets
Lower Bracketssome may be the same with a different finish / color)
46998-11 BRACKET, lower, with bearing, seal and retaining ring XL1200T, XL883L
46767-07 BRACKET, lower, with bearing, seal and retaining ring XL1200NS, XL883N
6014-10 BRACKET, lower, with bearing, seal and retaining ring XL1200C
45900103 BRACKET, lower, with bearing, seal and retaining ring XL1200X, XL1200X ANX, XL1200XS
5900107 BRACKET, lower, with bearing, seal and retaining ring XL1200CX
The following 2 users liked this post by shanneba:
RiverSouth (01-17-2019),
WKNDS (01-17-2019)
Trying to find out if there is any differences between upper and lower brackets with older models. The interior of one of the shocks is different, as one member pointed out.
Had an accident. Front shocks are bent. Dont know if the wheel is good yet. Minimum needs two tubes and sliders and lower bracket. New parts are very expensive. $800 for shocks only.
RiverSouth (01-21-2019)
