2007 sporster 1200 xl custom leaking oil
Old 03-20-2019, 08:32 PM
Btoulouse's Avatar
Btoulouse
Btoulouse is offline
Stage III
Default 2007 sporster 1200 xl custom leaking oil
Hey guys, i inherited my dads motorcycle. And ive come to find out its leaking oil. From what i can tell its the drain hose. I might be wrong, new to motorcycles. Ive attached a picture. Does anyone know what this is, or how to stop the leak?
It sarted leaking a couple days after about a 40 mile ride. Its emptied most of the oil in the tank.
Old 03-20-2019, 09:55 PM
aidoru's Avatar
aidoru
aidoru is offline
That is the oil drain hose. Check that the plug is well secured. If it's leaking from there you just need to tighten the hose clamp.
Old 03-20-2019, 10:04 PM
Btoulouse's Avatar
Btoulouse
Stage III
So its leaking from the top of the drain hose. Ive checked the clamp at.the bottom its secure. Is there somthing that is supposed to secure that hose from the top end?
Old 03-21-2019, 03:44 AM
Andy from Sandy's Avatar
Andy from Sandy
Andy from Sandy is offline
Received 3,752 Likes on 2,412 Posts
On the 2007 the hose just hangs down at the back of the engine.
Part #18 holds the pipe on the tank, #9 is the pipe, #10 clamp and #11 is the drain plug.
The manual just calls for the clamp to be done up securely.
Old 03-21-2019, 02:02 PM
TStephen's Avatar
TStephen
TStephen is offline
Check for a split hose as well.
Like Andy pointed out, having diagrams is always helpful. This is a great resource:
http://partsfinder.onlinemicrofiche.....asp?make=hdmc
Old 03-21-2019, 02:14 PM
Btoulouse's Avatar
Btoulouse
Stage III
So from what i can tell i think clamp 18 broke. Would that cause an oil leak?
Old 03-21-2019, 02:45 PM
Andy from Sandy
Yes it might depending on how tight the hose fits to the tank. HD uses a special type of clamp on the tank but for the drain hose I would hope a jubilee clip would do.
Old 03-21-2019, 03:48 PM
JerseyDoug's Avatar
JerseyDoug
JerseyDoug is offline
Definitely check for a split in one of the three lines attached to the oil tank.
I had the same situation on my 2011 XL1200C. Took me a while to locate the actual cause. The drain line had a small tear (on the back side) near where it exits the oil tank.
Old 03-21-2019, 03:53 PM
JerseyDoug's Avatar
JerseyDoug
When I replaced mine, last year, I used a small hose clamp. So far, so good.
JOE DANIEL (02-03-2024)
Old 03-21-2019, 04:15 PM
VAFish's Avatar
VAFish
VAFish is offline
Received 3,130 Likes on 1,626 Posts
A broken clamp could cause a leak, so could a split hose.
While I was in there messing with the clamp on a 20+ year old bike I'd just replace the hoses.
Quick Reply: 2007 sporster 1200 xl custom leaking oil
