Rear brakes sticking after taking rear pedal loose?
I just installed some new exhaust pipes, and in doing so, I had to remove the two bolts holding the rear brake pedal bracket. I dropped the bracket and pedal down to get clearance to remove the rear plate to the belt drive. I never took any brake lines loose or messed with the brakes in any way other than dropping the pedal out of the way. Now that everything is put back together, the rear brakes are sticking. They aren't completely locked up, but it's very hard to push the bike and you can hear them squealing. I've tried pumping both the front and rear brakes, as well as removing the master cylinder cover to let out any possible air bubbles. But nothing seems to work. I haven't taken the pedal back off yet. But is there anything else anyone can think of to cause this to happen? Thanks for any help.
2019 Iron 1200.
2019 Iron 1200.
I would start where you dropped the pedal and see is it sticking and then check the same on the master cylinder set up. Have someone push the brake peddle for you while you watch the caliper piston movement, it should push out against the pad and disc and and then recede slightly.After having a similar problem with my rear caliper it turned out to be the caliper piston and caliper o rings needed replacing (you might get a way with cleaning). Before arriving at that solution I checked the pad springs in the caliper were installed correctly and replaced the brake fluid. Sometimes a small piece of dirt can stop the brake fluid returning to the reservoir after releasing the peddle. My own discs were heating on on short spins.
Retrace your steps, to the point of putting it all back as it was or with the exhaust off.
I had a modified interconnect bracket made that was just a little low and touched the lever the brake rod connects to. A little massage with the grinder took care of that.
If all was well before and based on your description something must now be fouling.
MahaloMoFo (05-08-2019)
