87 Sportster Carberator
I assume you mean the rebuild kit for your existing carb is $90? Wow, seems extreme. Maybe shop Ebay for a better deal?
You can easily retrofit a later style CV40 carb instead of the (non-accelerator pump) butterfly carb you have. CV40's are cheap on Ebay, and so is a later manifold and mounting bracket. Just another option.
Also, rebuild kits for the CV40 are about $20.
John
John
S&S Super E is a good carb. What do you have now?
Back firing is probably due to intake or exhaust leak. Clamps securing manifold and/or exhaust clamps/flange may just need tightening up. My bike ran crappy when i had an intake leak i.e. popping and bogging.
If you eliminated your leaks and you are still running crappy, your carb probably needs a good cleaning. Make sure you have good fuel flow. Then remove the float bowl and the jets and soak in something like this...make sure you buy float bowl gaskets before you reassemble.
Shoot some carb cleaner up into every fuel port into the carb.. Since I do not know what mods you have done, it may be running rough because it is not tune properly....so you can try changing your jets if it still runs rough after the cleaning.
The bike has a Super E in it now. It sat for several years. I flushed the tank with new fuel. Not sure how it ran when it was put up. Motor is stock 883 with straight pipes. I will check for tightness today. I had planned on changing the exhaust .If it is popping thru the rear cylinder does that indict rear cylinder exhaust leak?
Check out this vid on S&S super E and drag pipes
Here is a S&S vid on jetting and tuning a Super E
I have a Super E myself. Great carb, and easy to tune.
Having said that, there is one huge issue with them. People tend to crank down on the mixture screw and crack the throttle body at the orifice in the venturi. If you have a crack in the body, you will never get it to tune properly and it will cause all sorts of issues.
Before you waste a bunch of time, take a good look at the orifice where the mixture screw seats. If you see ragged edges around that hole, or a crack coming from it, you will need to replace the throttle body. Ask me how I know.
Good luck.
Good luck.
